• BuzzTV 4000
    BuzzTV 4500
    BuzzTV 4900
    BuzzTV 5000
    BuzzTV VidSticks
    BuzzTV Essentials
    Sticky Threads can be shared among the BuzzTV models.
    Of course some things would be different, such as the specs and etc, but the options and setups should be the same in most cases and similar in other cases.
home screen issuses
dfr1960
33
2
8
yes I do
Hi
I changed my home screen format and now have no control over it.It keeps looping or constantly changing... i remember a post about fixing that while back but i cant find it ... could someone point it to me and Thanks in advance
Toothpick in the AV hole to bring the box into recovery mode and then factory Reset.
http://iptvtalk.net/showthread.php?42585-How-to-Hard-Reset
Or if you catch it just right, you can get the side-bar menu to open and then you can change that Home screen.
Its the 'MediaPlayer' Home screen that is the issue, so change it to 'Modern' or 'Classic'
When in the loop,wait for the Home screen to appear for that second and hit the right button on the RCU or it could be the down direction or the OK button. If done right, that will bring up that side bar menu and the Buzz Utilities where the Home screen selections are found.
You have to catch it just right thou and it will work. I have successfully done it like this 3 different times.
Keep trying till it works.
It may bring up the wrong menu so if that happens then try again.
I never thought to look there wondered why i couldn't find it.....and not trying to hijack my own thread but any word on the new file for these...this week has been bad for me with looping, stopping you name it etc.. not complaining just bringing it to your attention
thanks again for your help
not sure on release date.
I think we are passed the previously announced approx date now.
The team are currently working on some things that have come up with the VidStick and are refining the work done on the XR4000 model (which seems to be the testing ground for the 4500 model).
and do not worry thinking that you are complaining.
I have seen complaining and it almost always comes with remarks including words like 'crap' and all that kind of bs
What your are doing is 'reporting' your experiences and possible faults.
Respectful and responsible.
These reports help the Team
thnx :)
yea i know about the winnnners lol they wouldn't be happy if u gave them a tv and paid them to watch
I have had the box about 3.5 months and till the last week i would rate the box and system an 8 or higher out of 10 but this week that goes down to about 2
Kind of funny before I did the reboot with the toothpick thing I would loose sound and still have the picture going... now the picture freezes and the sound keeps going....
I try to give an honest account of what my experience is with this system including the service and box.
Thanks for replying
what i found out from friends a hide ip program help so much no not because of the box i think more for internet they get more working channels that work they didnt work before and way way less freeze and looping now anyhow try that when things get better you never now what may happen but its a very good try and make sure your vpn is on when you start watching anyhow good luck trying that you never know what may happen box maybe become a 10 lol have great day this is for usa I'm taking about dont know about Canada or other place but still worth try
Thanks for replying Marley
I will look around tonight for a vpn....my only question to that is why did it work good for the first 3 months without one....had a few hiccups but nothing that was discouraging
and I got the new box update tonight but still about the same with looping etc.
So that points me to the network or the server and I see they put out a post saying they where working on it
Hopefully they will get it before long:)
So earlier this morning things where working like it was this past week or so ...not good...I did a reset on the box and on the server ,,,now things are running fine at the moment .... keeping fingers crossed
I also did a reset yesterday but that had no effect
Maybe they got it fixed
Might help someone else
