Help
Finally got it working, there is sooo many outdated guides on this forum its hard to find the ones that are current.
Not all things work the same. There are one million different things to be understood with every aspect of IPTV and or Kodi and or emulators.
Things that are current will usually have a current date of which they were posted.
Your comments do not help. What would help is if you were to post what guide or guides you followed or what procedure you did.
We are a community afterall ... and we do not get paid to post guides for you or others. We do try and keep the forums organized but that is a never ending job, and thnx by the way for noticing :)
Do your part and post what worked for you instead of complaining that there is too much info here :eek:
Great.So you want to keep it to yourself.Well then my friend you might find it difficult to get any help in the future with that kind of comment.But if you should ever need any help and I can help you.Feel free to post and if I can help I'll be more than happy to.Have a great day.
