help with wifi
smallyjohnso
Feb 16, 2015
18
hello all... I have a 254 with wifi that's working properly. I travel often and would like to carry it with me ..I can get it hooked into hotel wifi but when it goes to the hotels acceptance page I cant seem to figure out how to hit accept. I have opened keypad and even tried every button on remote with no result any help would be appreciated thanks
Smally, there is another thread on the same issue with much smarter people than me, try to locate that one and see if it helps you. I cannot understand not having access to any features, if you do not have internet access at all, the box does boot up and you should be able to atleast go to the inner portal, there you should be able to select internet, you will not be able to surf the net or anything but the menus should be available, if what I said makes sense, do not connect the lan cable or your wifi until you are at the browser page (in the inner portal) and then connect the cable and see if the permission page pops up
