Help With NFPS Stalcker Client.
euly1
Apr 11, 2019
10
I am using an Amazon stick with stalcker client, everything is working great, I just can't get any of the X rate channels, do I have to use another url or change something in the setting to make it work?
Thanks.
The live tv x channels, according to the NFPS list of channels, there are some x channels, am I right?? I do not know if they are VOD or live tv channels??
Thanks.
The LiveTV Adult listings, as far as I can remember, were removed from the Channel list, if you were using Stalker PVR client.
Like Crazed, my memory is foggy, that far back.
*You should switch to IPTVXtra2 for Kodi 18, so to get access to VOD.
