Help with Kokaleka or OTT Navagator
Tubbs
Mar 25, 2015
8
Can I please get some help from the smart people on this forum.
I'm certainly not as savvy as most of you here I'm sorry to say I have a IKS 66 donation and I'm trying to get it to work on an Android TV box.
My box is what they call a TV box T9 it's got 32 GB of memory. Android ver.9 I had another service on it that was running pretty well.
What I'm trying to do is get the k o k a l e k TV to work, I downloaded it from this user forum when I start the program. it just asks for my user & Pass which I use as my route number... nothing happens...
Or the Ott navigator
I'm not sure if I use the playlist or the Middleware tab,
Then in the middleware tab? Mac portal-Stalker Portal or Xtream codes? And what do I do just make up a MAC address if I'm using Ott..?
I'm having trouble with the k o k a l e k a because it's just asking me for a username and password. That I got off this form. Where do I put the http s1 information in for IKS 66.
I was able to get it to work on a generic stalker, but there is no guides and stalker is not very good.
Any help would be greatly appreciated trying to set this box up with k o k a l e k a
Thanks for reading this.... TUBBS
There are a couple basic things to ask.
What version of the Kokaleka app did you install ?
Version 3 is the most recent.
When entering the username/password (credentials), it is case sensitive so ensure you get that correct.
Your credentials for iptv66 will (may) have 3 letters included.
One at the start, one in the middle and one at the end. So make sure you are not confusing a zero for a capital letter O.
If you have all this correct and still same results then uninstall the app and reinstall for results.
I don't think you need to worry about the server portal. If I remember correctly the server portal will be an automatic thing, no need to worry about that.
This app will know what your server portal is , thru your credentials.
it's been awhile since I fired up this app. so going from my sketchy memory only :)
it's been a while since I fired up this app. so going from my sketchy memory only :)
I'll give that a try. I did think that the secure URL was "built-in" to the APK. but wasn't sure.
Thank you very much for the help...
