Help to find out the provider
Nitros83
Apr 9, 2017
13
Hi all,
I have a mag box with the subscription from a guy, his service is very good and stable however this guy disappear and I need to renew it I managed to find the portal address which is http://xyz now this take me to stalker portal I was wondering if someone recognise the provider or can tell which providers use stalker portal?
Thanks in advance
I edited your post and removed that URL, which is not supported here at iptvTalk
Since it has expired thou and seems your contact is not around anymore, why not try a subscription from the source.
iptv66.com
or
iptvrocket.is
Yes, as this guy was I reseller so I'm trying to find out the source are those two providers use stalker?
Open the iptv66.com website and seen on their web page are your answers :)
But even with Stalker support, it does not necessarily mean your guy was sourced thru them.
One sure way to tell is look at the channel lists. They would have to exactly match to make the call weather it is same source or not (or an order number may also work).
A domain name of .ru is a Russian Domain... so most likely that is where your guy is from.
There are many iptv providers using the stalker portal none of the services here use
http://xyz
Nitros83 maybe this is your server!??lol
seriously though just take your
http://xyz
paste it to your browser
but add to the front of it free m3u it might lead you to your providers site
