help on win 10 pro
I picked up this computer for my grandson to play mind craft here is the spic's
intel{R} CORE{TM} i7-4770 [email protected]
12GB 64-bit memory
1TB Hard drive
It had a AMD 2gb radeon 280 video card in it .I have a GeForce gtx 1070 a to put in it so i had to put a cr500 power supply in it and the 1070 .the computer will not pick up the 1070 no matter what i do the 2gb radeon 280 video card shows as the card i took the 280 out .there is a program called GeForce experience that should pick the card up ..i had tried everything i know any help would be great
Have you the most recent video card drivers installed? Go to the MSI GeForce site and get their driver. Also uninstall the radeon driver and reboot with new vid card.
Also, you may need to use the Radeon software to remove the old video card driver.....it's a PITA but I have also assumed that the vid card you purchased is compatible with your motherboard.
Thanks for the replies guys .the card did work, I put steam on it and downloaded two of my big games {American truck simulator and tomb raider}both games ran at 60FPS I just wanted the right driver on it .i should have left it alone .i ended up dropping a screw on the damn board and frying it lol .i ordered a new MSI 970 gaming motherboard hope it turns out better lol
Youse suppose to un-plug that thar thing before tinkering around inside...!!! ;)
