Help needed please
chrismarson1
May 28, 2015
6
Hi guys. I have a donation with iksprivateserver but i'm unable to get the pvr client working and it says error and unable to load channels.running kodi 15.2
I have tried clearing data from tv area and disabling and enabling.
i bought my donation from prostream.do you think i need to change mac address?
i really like the pvr client rather than ivue.
Thanks for any help
Cheers
chris
Thanks for any help
Cheers
chris
Ok to clarify there are 3 option.
1. IPTV Stalker. Its a video addon like Genesis.
2. Stalker PVR Client (ver 0.84 which comes with Kodi 15.2)
3. Starlket PVR Client NFPS (a custome version with NFPS settings; THIS ONE DOES NOT WORK ON ANDROID for me)
Now I presume that you want to use option 2.
So I would do the following:
STEP1
Change Mac; make sure that the fort 3 set are 00:1A:78
STEP2
Setup your link for remote url to
hxxps://papiao.is/main/EPG/mac/00:1A:78:XX:XX:XX/donation/XXXXXXXXXXX/fname/NFPSF4
xxxxxxxxxx= donation
:XX:XX:XX: last 3 sets of your mac
I have used tinyurl to make the link shorter and make entry of the link less error prone.
STEP3
token = blank
13 digit serial number random alphanum
4 char device id
4 char device id 2
last 6 digits of donation as signature.
STEP4
enable addon
enable live tv
you will get an error that it cant load channels. Close kodi. And restart.
Hopefully this will work for you.
