Help Needed ASAP.
Eddy5678
Banned
May 31, 2016
21
Installed the latest IPTVStalker PLUS. Put in all the info required. And make sure channels play and they play just fine. But the problem begins at the end when I try to Start M3U server. I get an error telling me.:
"Server not started. Wait a minute and try again"
This has been going on for the past 3 days for me. I wait 1 minute, 2 3 even 30 mins and I still get the very same error.
I tried to change my mac and do an IPTV reset in the iptv66 site. Did not solve the problem.
Please help me thanks.
Try this. Enable the server, then completely exit Kodi, then restart. Check to see if the 'server' is started by clicking on 'start'. It's also possible that there might be a competing server running on Kodi, so changing the port number could help in that case.
There isn't much else you can do with it... its one of those things that either works, or doesn't.
