Help! Fail to get stream url.
Waldyhary
May 27, 2016
9
Everything load on my portal, all channels and guide but the same error appears "fail to get stream url. I'm using kodi 16.1 stalker client. The dealer went out of busines and I have no way to reset my donation.
if you are getting any channels at all then that tells us that no one else is using your donation.
I might be able to find your info needed to perform a reset at the website , depending on how the reseller set things up.
I would need your email and any donation numbers he gave you. Send to me privately.
BTW, the iptv here is only showing the Music channels, I have not done or tried anything yet to try and fix this but there are issues with channels, it seems
