help config stalker
John
Feb 13, 2015
62
2
Donation 1 IPTV + Free IKS
I go to Stalker client
portal 1
mac address 00:1A:79:00:00:00
Time Zone leve
login Donation #
Password Donation #
Guide
Preference Prefer Provider
Cache Guide Data on
Cache Time 24
XMLTV
Scope Remote URL
ADVANCE
Tken blank
Serial # 12345678951111
Device Id kkjjhhgfdsswrrt
Device ID 2 blank
Signature Blank
is my config wrong
starts to load get authentication failed
still says failed
for server address I have 2.nfpsserver.tv
on my donation paper it says
IPTV: 2iptvprivateserver.tv
IKS SERVER: 2.nfpsserver.tv (Dish ) 65.nfpserver.tv (Ciaro TV 50
Port:12010
Deskey
what is the input I should use for sever address
Yep, your MAC address was wrong. Make sure the MAC address you are using (00:1A:78:XX:XX:XX) to configure the client is the one you see at the Donation Checker. You have to create more credentials as well. Follow these directions except for the EPG section. That section doesn't have to be configured to the load the channels. We'll worry about channel loading first. The instructions will tell you which portal to use, depending on your version of Kodi.
http://iptvtalk.net/showthread.php?24831-PVR-Stalker-(Kodi-Built-in)-Set-up-tutorial
when I go to checker I get
Status Active
remaining days 364
mac address 00:00:00:00:00:00
when I open Portal on my box it says mac address is 00:1A:79:00:00:00
Status Active
remaining days 364
your MAc is showing all zereos, will not work. You need to get a MAC linked there.
And use the server URL portal as ilan shows from above post #6
Your MAC needs to be fixed. It needs a prefix of 00:1A:78 and with 6 more digits attached.
http://www.miniwebtool.com/mac-address-generator/
still no luck changed mac address did not say it was good or bad so will try again tomorrow thanks for the help I did go back tried to go to checker just keep asking if I am a robot
you did get it change with success, but the last digit at the website shows a 7, while what you sent me shows a 1 as the last digit.
Leave it as a 7 at the website now, just change your MAc on the stalker to match.
I sent you a reply message.
Still can get my box to work .Would it be a good idea to uninstall kodi and reinstall clean version to see if it is just curupedted if so what is the best version to install
I doubt your installation is corrupted. Rather, there is most likely a configuration issue.
At this point, here is what I would do...
Disable PVR Stalker and set defaults. Shut down Kodi.
Go to the Donation Checker. Make sure all your settings look proper. Jot them down so you have them for re-configuring PVR Stalker later.
While at the Donation Checker, do an IPTV Reset.
Wait at least 15 minutes then restart Kodi, but do not enable the PVR. While disabled, configure the PVR following these directions to the letter:
Once completed with the configuration, making sure everything is accurate and complies with the directions, enable the PVR.
