H96 guide problom
Shadowdrow
Nov 21, 2015
80
Ummm
First off let me start out by saying I I've been using the stb emulator 9.03 on my Amazon Fire TV box and the guides fine. Install stb emulator 9.05 on my h96 Android box .all the settings are the same but the guide seems to be a few hours in advance of what I currently am watching. The only thing I know if that's different is that a 9.03 version on the main screen I was able to set up a location Eastern New York . however I'm unable to do so Within 9.05. I don't know if that has anything to do with it or not... help
Are you using a vpn ? If so you need to turn it off uninstall the emulator. and then re download it .then reinstall it that's what I did. for some reason it goes by the location you use to download it..
