Guillermo del Toro's Pinocchio (2022)
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,680
457
83
This version of Pinoccchio although hidden nicely, is much propaganda done thru hollywood. I gotta say that I did kinda enjoy this thou, the animation (prolly CGI mostly) is terrifically done to match a Pinocchio setting.
With voices of Ewan McGregor, David Bradley, Christopher Waltz ...
The story is good too. But the underling meaning during many scenes was there to see. It's quite sinister when you really pay attention.
Ron Perlman as Podesta should raise some eyebrows. Yes I said that correctly.. Podesta
If you want to know the meaning of the story...
There is unbearable suffering in life. That is what life is.
The only thing that sets some apart from others, is that some will bear that differently then others.
It's up to you to choice which are you.
But in reality it's not up to you at all (according to them).
Are you gonna keep yapping or are you gonna sing ? !!
that's the story.
