N newguy12 New member Dec 16, 2014 41 0 0 Aug 13, 2018 #1 Aug 13, 2018 #1 I am not getting the guide at all. anyone else not getting the guide. if you getting the guide what do i need to do. this is the second day.
crazed 9.6 Transparent Wall Technician Knight Order Oct 31, 2014 16,675 441 83 Aug 13, 2018 #2 Aug 13, 2018 #2 try the info in the link below and see if it helps... http://iptvtalk.net/showthread.php?36683-time-servers
kens Readings Master 10 Years 1K Days Feb 2, 2016 915 41 0 yes i do -Y(not) Aug 13, 2018 #3 Aug 13, 2018 #3 I thought the Provider guide was fixed? Should not need this now. Try to reboot your Unit. (Unplug for 2 min's then power back up). Guide data should load automatically. /kens
N newguy12 New member Dec 16, 2014 41 0 0 Aug 13, 2018 #4 Aug 13, 2018 #4 I tried both options there is no guide still
