GSN no sound
dreamsr is running the mag 270 and so unfortunately there is no option to change the Player :(
That channel does have Audio thou and so I'd guess that your Mag may be having compatibility issues with that channel , which a different player may have helped with, but that's not an option here .
I have reset your code dreamsr and also I have set the Country lock to All Countries, which might help with that Blocked error message you have been seeing.
You can try going back with the MAC method or stick with the Playlist method, either way should work.
That channel thou may not be an option for you as they may have changed the audio format on that channel or something like that. A receiver reset may help. Just a power cycle is all that is.
oh and I saw all this thru the recent Visitor Message you sent Ryu..
Ryu is off-line for a few days with family matters .
