Genesis problem please help
echofan
Mar 4, 2015
10
hi,
not sure why this is happenning but I recently upgraded my kodi to 15 and right about the same time my genesis movies option only shows me trailers, the other categories work fine with genesis.
(other addons are working fine too)
this probably a simple setting but I cant find it so I was hoping someone can point me in the right direction
thank you
Yeah since the genesis upgrade it has been wonky I had a similar issue I just uninstalled it an reinstalled and it fixed what ever happened to it I would suggest you give that a try.
this is something I would had normally done but didn't..
just tried re-installing and it works now
almost 2 days looking for settings and stuff, wow
thank you man
