Formuler Z8 - Specifications
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,675
441
83
Formuler z8
Specifications
Output Resolution: 4K (3840 x 2160)
CPU : Hisilicon Quad-core 64bit
GPU : Multi-core high-performance GPU
RAM: 2GB DDR4
Storage: 16GB eMMC
Operating System
Android 7
Networking
2.4G / 5.0G Dual-band - Dual Antenna
Gigabit Ethernet 10/100/1000M
Decoder
Video decoder : 4K@60fps),VP9,H.265(HEVC) , AVS , H.264(AVC, MVC) , Real , MPEG1/2/4 , VC-1
Video Format : TS , MKV , FLV , MOV , AVI , RM , MP4
Audio Format : MPEG-1 Layer 1,2 , AAC-LC , HE AAC V1/V2
Image decoder : JPG , BMP , GIF , PNG
Support Language : Global
​Dimensions
Length: 105mm
Width: 105mm
Thickness: 22mm (Install Antenna 121mm)
Color: Black
Ports
USB2.0 : 1
USB3.0 : 1
IR Extension
S/PDIF
HDMI2.0a (CEC)
Gigabit LAN
Dual-Band Antenna
Type : 12V Adapter
Power Consumption : Max. 15W
Standby Power : Max. 0.5W (Ultra low power)
https://www.formuler.tv/z8
