That does no tell me anything.Code:https://www.formuler.tv/user-manuals
Code:https://www.youtube.com/watch?v=Y5cB4BBqMME
I finally figured this out not only was the guide light colour but the picture quality was off. Change the video settings to SDR. Then Hold the V.Format button to bring up the PQ settings. There is a ton of colour settings as well as many more settings. This can be set while watching a channel, this made a huge difference in picture quality.In classic epg the guide is light in colour I have changed a setting where it was full of colour. What setting changings it back to full colour?
For me it sticks not sure why yours isn't. I do not have to change it again. I know there is still some bugs with this receiver.It seems the even if I change it to SDR settings are not saved on reboot. How did you make them stick?
thnx profster for bumping this, good idea.This is very good information for others... Perhaps could we change the topic and put it in as a sticky!!
i think you need to disable HDMI auto adoption in android settings.
Where to Purchase Formuler Z7+
Formuler Z7+
R |
Formuler Z7+ 5G is Rock.
Formuler Z7+ USB WiFi adapter compatibility list
