Formulae Z11 pro
You are most likely looking at the Formuler's MAc.
But what you want is the onboard IPTV app's MAC
That's the MOL app , I think the Z11 still uses the MOL app.
So open that app and look for the MAC there, might have to open server settings.
Or sometimes the MACs will be shown on the bottom of the device.
Or here's a trick
The Device MAC and the MOL app are exactly the same except them first 6 digits, so just replace the first 6 digits you see on that MAC and replace them with the 00:1a:79
Then you should be good to go, add that new MAC to your code at the website.
