fire tv stick quick and dirty fix
ok was bored started experimenting i have kodi on galaxy s5 working perfect and on my firetv stick.been the stick was giving problems even though it has the latest kodi-15.beta 2 it was buggy well
i took the folders data and userdata files from the galaxy s5 which are under android/data/org.xbmc.kodi/files/.kodi and put them in a folder i made call kodi_backup on my desktop. then on the stick i went to setting apps and click on clean data yes then clean cache yes now i launch kodi to make sure it is 100% like a fresh install yes it is then using the latest adbfw128 after it connect i hit restore waited until the message pop up done then plug it back in on tv launch kodi bingo no errors and less clutter.hope this helps others from what i read if you have kodi on pc you can do the same thing
