Fire Stick best IPTV build and guide
darren2331
Nov 5, 2015
7
Guys,
I have an amazon fire stick and a paid donation to IPTV. Have tried a few builds for a tv guide only none seem to work efficiently (Spinztv, ChrisB, Blackbox). Does anyone have any suggestions for a light build with IPTV access and EPG only? Apologies if this is on the forum as I could not find it.
Darren
Why don't you just use plain old Kodi v15 or above with confluence skin & use the pre-installed PVR Client which works in conjunction with the built in Kodi Live TV feature which, when correctly configured using latest authorisation protocol provides full EPG, channel list etc.
From what I hear/read, memory is sparce enough on a firestick as it is without clogging it up with any of the above mentioned builds which are packed with addons the majority of which you won't need or ever use.
Yeah that was my plan but I cannot seem to get the PVR to interface correctly, I'll keep looking.
DAZ
Most would suggest that you use PVR Stalker, although I've had decent success with IPTV Stalker in addition to PVR Stalker. What version of IPTV Stalker are you using? What do you mean it is hit and miss. If it's configured properly, it should work, and there shouldn't be a gray area.
It appears to be a hit or a miss depending on which build I use, works fine with Chrisb but will not always access IPTV when using the channel guide uses other less reliable sources(channel1 SALTS etc). I think I have used a few different versions of IPTV stalker and there in lies the issue in not using the most up to date version. Will try using PVR stalker, can you use a EPG through that one?
Daz
I would jetison the builds. Get back to confluence and configure things so they run smoothly.
You need to use the latest version of IPTV Stalker, version 9.0.21. It's available here...
http://iptvtalk.net/showthread.php?...nd-serial-number-enabled&highlight=ivue+guide
The latest build of PVR Stalker NFPS has the EPG built-in. It's available here...
http://iptvtalk.net/showthread.php?7161-Stalker-Client-NFPS
If that doesn't work, the native PVR Stalker will work if properly configured.
Thanks bud, I will do it tonight and let you know how I get on. Out of interest are you using the latest Kodi or the Beta version?
Daz
I also want to know the OP's situation but to your answer, what would be the benefits of using both IPTV Stalker and PVR Stalker NFPS? Wouldn't they just show the same channels anyway?
Hello! My name is Victoria. I am very very new to the. KODI sticks. I have a big problem. I just got done writing a quite lengthy explanation and introducing myself me a copy and then paste it to you and explain my problem and see if you could help me I will warn you it's a bit lengthy is house to basically I guess in a nutshell with these with the cold PVR, TV Guide westerns and getting everything to work but again I am a newbie
Best build to me is Spinztv premium lite. I have tried the rest and they seem boggy or more for UK users. I use Stb emulator with iks but lately the service has sucked balls next time i will go with spinztvpro or i here also a newer iptv called REBOOT is pretty good has bet-mtv and vh1 in his pkgs hes's still working on his guide though but all channels mostly in HD
