fast forward and rewind VODs
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,680
457
83
if you find that you can not fast forward or rewind VOD selections with Dreamlink's onboard Player, then install Wuffy Media Player and that will solve the problem for you :)
You can find Wuffy Player in the Local Market under sub heading 'ETC'
At this point you will also need to set your Dreamlink so when opening a VOD selection, the box will ask which Player you want to use.
To do that, open the LiveTV or Vods and then hit menu button and choose Settings and in there find the 'External Video Player" and set that to ON
fast forward works like it should but rewind does not. To get the rewind to work, first hit the fast forward function then quickly use the rewind function and it will then work
