EPG Ninja on Fire TV
racingpr
Jan 26, 2016
5
Hi to all.
Yesterday I set up my kodi follow video tutorial and works perfectly except guide
Info
Kodi ver. 16.1-ok
FireTV-ok
EPG Ninja-not working not loading guide from client
PVR Client-Stalker Client ver.1.0.8 ok
IPTV-ok
Check status on first post and said status ok. What I need to check for guide to works?
Guide set up
XMLTV Only
Scope: remote url
Remote url:special://userdata/addon_data/pvr.stalker/epg_xmltv.xml
Hi Racingpr
are the channels loading in the guide, just not the guide info ?
check your kodi log,
do you see the following ?
Edit by psycon. marty, you are using the wrong epg updater.. uninstall that one and install the STALKER epg updater
[/B]also what is your location and ISP ? [/COLOR]
Hi to all.
Info
Kodi ver. 16.1-ok
FireTV-ok
IPTV-ok
Guide set up
XMLTV Only
Scope: remote url
remote url is wrong. (or you have to ensure the STALKER epg updater is set to save to the same folder) instead of temp
Your epg_xmltv.xml file should be saved to Kodi's temp folder. You can browse there to establish the path, but first you'll need to unhide hidden files and folders. Do that by
System > Settings > Appearance > File Lists > Show hidden files and folders
Now, browse to the file by following this path under Local Path...
/sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp/epg_xmltv.xml
