Driver Pack Solution
c/p
DriverPack Solution is a free driver updater tool that, with just a few clicks, finds the proper device drivers your computer needs and then downloads and installs them for you - no clicking through any wizards or installation prompts.
https://drp.su/en
Warrning: please read all info and do it on your own risk.
  • Like
Reactions: crazed 9.6
thanks crazed 2.0. :cool:
usually i just keep in usb and install only network card driver which is most important for me and rest of them i just download from manufactures sites by model number.:cool: kof
The BEST WAY to do it...! Kept up to Date...! Have had Problems with Toshiba Support tho as They don't have them listed like They used to...! Had to use a Re-Install of Windows Disc to get Them and Hope that Windows Update will get Them as needed...!
