Dreamlink T1 - my first look
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,675
441
83
the T1 tester arrived here couple days ago.
I made room for it on the entertainment consule, next to a bunch of other devices and even robbed an ethernet connection from another device and connected the T1
Powered it up and got an internet connection (it was slow to appear, but it did).
Then things came to a stop.
I could not open the Server settings menu nor the Market menu.
I also noticed that there was no initial update which I heard should have taken place.
Talked to a couple gurus here and saw that yes indeed I did have the old original software version and no update took place.
So rebooted and stuff, but still no update.
After some contact with dreamlink team thru our guru members here, we decided it was my ACtiontec router (which had given problems in the past with the T4 model I have here, the team since fixed that with a bin release).
So with the T1 in hand , off to my buddies place to try it thru his router internet connection :)
Smart idea right ?
I gets there and what does he have but the same Actiontec router (same model exactly).
I had to chuckle.
Anyway I tried it. And the darn thing worked. Took the update, had success and everything was working fine.
Home I go and after some investigation saw that I had the ethernet from a piggy back router I use (because of all the many devices I have connected).
Changed that to an Ethernet straight to the Actiontec and all is good :)
Other devices work okay thru the piggy back router , so I never thought twice about it. Not till I seen buddies Actiontec work fine.
I told yous all that so I could also say thnx Android Man and NBS for their support thru this, and especially to the dreamlink team who were ready to ship my Actiontec router to them for study and a fix.
thnx guys and sorry about the false alarm :)
I will soon get some guides posted up for this T1 model, but really there is not much that needs explanation with this T1 model.
It is a fine box with great user accessibility and ease.
They have their own Market onboard with apps available for download (4 or 5 versions of Kodi are there)
They have the dreamonline app which is the server app and that works flawless.
Scrolling is fast in Kodi and the DreamOnline app. You will need that as there is no 'page up/down' on the remote. Great picture quality, and very easy to set up for IPTV. Currently 27 apps in the Market. New users should expect to see a firmware update when connected to the internet. There are 2 VPN apps in the Market (FlashVPN and CloudVPN).
My only minor negative is the limited remote... very basic functions.
Dara the remote will page up and down if you use quick use by hitting OK on remote, and using the up and down arrow on remote. If using the epg mode it doesn't work that way as it gives you a couple hours in advance for each channel.
