DOL2 and Dreamlink SW only updates via wifi not Ethernet
ermalebo
Aug 23, 2017
8
Why Not
Ethernet works to stream on the Dreamlink. But, the initial software update and an audio codec update repeatedly failed over Ethernet. When I unplugged the Ethernet cable and switched over to wifi, the downloads then worked on two separate occassions.
Has anyone else experienced this odd behaviour?
Thanks.
