Dlite ISP Problem
shadow..... that's a good idea. 85146....... no I didn't have the portal info in the box when it was at my friends because I didn't have the URL, user and password info with me. I did get the "edit portal" screen so I could have entered the portal info IF I had it with me. Like I said........ I figured no big deal...... I had the needed update so I'll take the box home and put the URL, user and password info there. However, when I got it home and fired the box back up........ instead of getting the "edit portal" screen like I had before....... I got the "cannot connect to market" red warning box. I then hit OK and my box went to the "blue screen of death"..... that's the one with spinning white arrow...... I now affectionately call it the "you ain't going nowhere screen". LOL. I'm gonna try the IP sniffer. If I don't get anywhere I'll enter the portal info using my friends ISP...... and then bring the box home and see if it still works. I kinda doubt it will because I believe these boxes have to talk to their cloud IP, but it's worth a try.
yes they do need an internet connection active and working before you can proceed past that screen.
I had a bit of the same issues and what I did was disconnect and reconnect an Ethernet cable a few times till it showed connected. Did that with the box powered on.
It shows this in the setup sticky thread.
Also go into Network menu and turn the connection off and on and off and on a few times
Yeah..... I did all that.... tried both DHCP and static IP too..... bypassed router, etc. It always says "YES" it's connected to the internet but I still get the screen of death. I believe it IS connected to the internet, but it's just not talking to the cloud server that enables it to proceed. I think my ISP has that IP blocked.... either intentionally or non-intentionally, who knows. The box probably works great for 99.99% of the people....... I'm just the .01% with a weird ISP.
