Discontinuation of guide_kens & guide_iptv
I will stop producing guide_kens.xml and guide_iptv.xml (Reseller Guide that did not contain any Provider or Forum information).
Both of these guides are compiled with the old channel names and are only used with Playlists that have been made prior to June 2018.
Since I have Posted a new Template (2nd Update on July 23rd.), it is advisable to make a new Playlist and use the new guide_ks.xml Source URL;
https://raw.githubusercontent.com/kens13/epg/master/guide_ks.xml
Will continue these until approx. Aug.1st.
PM me with any concerns
Kens, really do appreciate all you have done for the community. Just to verify, will you still continue to update the “ks_xml” guide, or are you stepping away completely? If so, will the service itself pick up on supplying a guide? Or is the guide basically dependant on someone willing to contribute to the maintenance of a guide? Thanks again for all you do “voluntarily”.
