Device conflict and authorisation failed
davydots
Dec 18, 2015
12
I'm having serious issues with this,I only have this on one device and I'm unable to use it! I either get device conflict error or authorisation failed errors,I've changed the mac many times and reset it and still is am unable to use it,please help!
What are you using...Kodi's built-in PVR Stalker client? If yes, run through these instructions to make sure you have all the bases covered. (You are aware of the portal address changes for NFPS, right? This is covered in the instructions.)
http://iptvtalk.net/showthread.php?16461-PVR-Stalker-(Kodi-Built-in)-Set-up-tutorial
If it were me... 1. I'd go to the Donation Checker to make sure of the portal address. 2. Then I'd disable the PVR and TV. 3. Then I'd set defaults in the PVR. 4. Then I'd configure the PVR according to the directions. 5. Then I'd enable the PVR and TV. 6. If it doesn't load, I'd do an IPTV Reset.
Donation Checker NFPS:
https://papiao.is/main/search_nfps
