Correct Way To Do Manual Factory Data Reset On Avov Products
[h=1]Factory Data Reset[/h]Having trouble with your box? Is something not working when it should? A factory reset might fix your problem. Both resets perform the exact same thing. Only use the manual reset if you cannot get the box to boot properly. BEFORE YOU CONTINUE, make sure to re-input your information when you start up the box for the first time. Also write down or save any information you might need, the factory reset will completely wipe your box of any saved data.
Regular Factory Data Reset.Go to the settings tab in the main menu > Click on the pink system info button > Click on factory data reset.
Manual Factory Data Reset.
1) Make sure the box is connected to the TV by HDMI or RCA
2) Make sure the power is plugged out of the box
3) Push and hold the reset button with the pin for 10 seconds
4) Continue to hold it down and plug the power into the box
5) Hold the reset button for at least another 5 seconds and then let go
6) Proceed to wait for a bit while the box resets, it should open up again in console mode
7) Select the factory data reset option
8) The box will perform a factory data reset and reboot
9) It should then boot normally and start working. If it boots into the console mode again, make sure to just select perform normal boot up (I believe it is the first option)
C/P Avov Technology
Did Factory reset, but now stuck on console…..
C/P Avov Technology
