• BuzzTV 4000
    BuzzTV 4500
    BuzzTV 4900
    BuzzTV 5000
    BuzzTV VidSticks
    BuzzTV Essentials
    Sticky Threads can be shared among the BuzzTV models.
    Of course some things would be different, such as the specs and etc, but the options and setups should be the same in most cases and similar in other cases.
BuzzTV XR4000 Restars when being Shutdown
amotab
Jun 16, 2020
2
yes i do.
Hi,
I've Buzz TV XR4000 and XRS 4000 boxes
My XRS 40000 is working fine but XR 4000 (V20200607) started acting up by restarting/rebooting every time I shut it down.
I'm on latest version of software on both boxes but only one is acting up?
Any solution is appreciated.
I experienced the same thing for awhile, till i figured out that it was because I held the power button too long or hit it a second time by mistake. I'd shut it down and walk away and upon coming back the box was on again. This kept happening time and time again until I was purposely careful at how I shut it off, then all was okay after that.
Also set your PowerKey function.
Settings > Advanced Settings > Powerkey Definition
I set this to 'Shutdown'
