BuzzTV XPL 3000 2018 Model - No Signal
bhuvi100x
22
So all was OK and suddenly I have No Signal on TV
So I tried the usual
Changed HDMI Port on TV
Changed HDMI Cable
Changed TV
All samw - so I find RESET in the bottom but whats the proper way of doing it?
I tried RESET - HOLD - POWER REMOVE,POWER ON - RESET STILL ON HOLD
Now its just RED status, and NO SIGNAL
Any advice?
Changed HDMI Cable
Changed TV
Any advice?
disconnect hdmi
disconnect power
wait a second then reconnect power
reconnect hdmi to powered up dreamlink
any results ?
this kinda thing is usually associated with HDMI issues ,as you guys probably know.
If you have an HDMI Switch or access to one, I would try using that to fix the problem. I found when I had issues like HDMI not be recognized that after I used the Switch and then back to not using the Switch that the problem seemed to have gone away.
Maybe its the power boost that the Switch sends to the HDMI port that fixes it, I do not know, but did seem to work for me.
Them HDMI Switches are not cheap thou, so make that your last resort and follow floder's methods first
I contacted Buzz and they asked me to send to them and they fix and send back - but I assume there would be a simpler fix
I am interested in crazed 2.0's reponse, I did use a HDMI splitter with a HDMI switch. The splitter split the signal, and then went to a HDMI to RGB ( for DVD Recorder ), but I then use direct to TV as I didnt want that setup
All worked but then now no signal
