Buzztv devices and their tutorials
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,675
441
83
Hey guys and gals.
I just wanted to say that with all these new and older buzztv devices, that we at iptvtalk have added sticky tutorials to some buzz sub-forums but then we miss some in other Buzz sub forums.
For example, a member was looking how to fix the error with incorrect format on his/her X5 model.
We have the Sticky about that in the 4900 sub forum, but no other sub forum, but the tutorial will be the same for other buzztv devices as well.
Thing is that most all tutorials will be the same or similar for most all buzztv devices, so using one tutorial for multiple buzz models should be fine.
Of course with new models and new tech, there will be new things not seen before and we will try getting that info into Sticky threads in appropriate sub forums.
But guys and gals if you cant find a certain answer or tutorial that you may need for your buzz device, you can probably find your answer in another buzztv sub forum.
We have been trying to keep up on these tutorials placed in correct subs but the buzz team just keeps producing more and more devices. Which is a good thing but it's hard to keep up with them :eek:
But they at BuzzTV do make things easy in the fact that most all their devices work very similar to each other, except of course the new tech and ideas that go into their newest products. :)
So, in summing up, if you cant find an answer in your particular sub forum, then look in the other buzztv sub forums.
Or post a comment and ask thru the forums, there will be members willing to help out :)
Hint: the older ones usually have more Sticky threads :)
