Buffering
koolface
May 21, 2015
27
n someone explain this to me...when I use iptv pvr simple client I get buffering on almost all channels almost everytime of the day and night but when I use the ivue guide I have issues what so ever...btw I have a donation with iptv66, thanks for any and all help.
P.S. I running kodi on a MQ3 box.
You are definitely on to something. I had the exact same freezing on both my laptop and my ott android box, same settings on both, same repo's etc. I decided to redo kodi on my laptop. Did not enable the iptv simple client this time . I left the ott box alone as an experiment. When I was watching the ott box, constant freezing. I loaded up the new kodi on my laptop, turned stalker on...no freezing. so I went back to the ott android disabled the simple client and wham absolutely no freezing anymore.
I believe it's the server itself that's causes the buffering issues.I think they need to do some maintenance on the server,so it can perform better.
It's not a server issue, I think its more of a kodi issue. Mine has worked flawlessly since last night and that's never happened. The mods here shouldn't be so quick to dismiss people when they have suggestions because at least for me this one worked.
