Box does not connect
nobravo here
Still can not connect on my TWO boxes.
reset to factory
reset modem/ router
checked all numbers and URL
tried wireless and hardwired
tried to connect via phone hotspot no connect
can connect to apps and google on Avov box
HELP
At this point nobravo, I can only suggest again, to send me the code and your email and the MAC addy. I can check on this.
nobravo
avionics here
did you find your fix for your units?
i have three avov with identical problems and tried the same things suggested to you . going on six days here.
i emailed crazed o2 with my codes and waiting for replly at xxxxxxxxxxxxxxxxxxxxxxxx.
all of my units have the aps loaded are working ok, that is utube etc
would appreciate any help
avionics
Double check the MAC addresses on the boxes. Earlier this week I had an AVOV box change its MAC address. Do not know how or why it did this but that was the cause of a similar problem with one of my customers. I discovered this only by accident!!! At least I think it was the box and not the server.
box bloccked by provider
I think that is the internet provider block the server I have 2 friends with the same problem in they house, when they try your box in my house everything is ok
Hi, I am new to the forum but to not to iptv which I've had for over 2 years. I have the same problem, my only avov box tvonlline does not connect to the server no matter how many time I reset the donation, mac is good and I can use my market app. I am now positive that my internet provider is blocking my server because I connected to my cellphone internet and the box connects just fine but very slow since my phone personal hot spot speed is very slow. Any ideas on how to go around the block, an alternative server or do I need to change internet provider? the next just might do the same to me. I have been without tv for about 5 days, please any help will be greatly appreciated. THXs
box blocked by provider
Hi, I am new to the forum but to not to iptv which I've had for over 2 years. I have the same problem, my only avov box tvonlline does not connect to the server no matter how many times I reset the donation, mac is good and I can use my market apps. I am now positive that my internet provider is blocking my server because I connected to my cellphone internet and the box connects just fine but very slow since my phone personal hot spot speed is very slow. Any ideas on how to go around the block, an alternative server or do I need to change internet provider? the next just might do the same to me. I have been without tv for about 5 days, please any help will be greatly appreciated. THXs
