Beware of cloned Dreamlink T6 receivers !!
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,675
441
83
IF YOU HAPPEN TO HAVE BOUGHT A CLONED T6 RECEIVER ALREADY, DO NOT LOAD OR EVEN ATTEMPT TO LOAD A BIN FILE ONTO THAT CLONE.
YOU WILL END UP WITH A BRICKED RECEIVER THAT IS NO GOOD.
Clones have been bought from aliexpress and they are out there.
Be sure of what you are buying and I'd stay away from ebay and especially away from aliexpress when shopping for a Dreamlink T6
Seems a person did just that recently, he loaded or attempted to ,load a file onto his clone and that was the end of that.
DO NOT LOAD or attempt to load a bin file onto a clone T6 receiver.
Don't buy a clone. I am only going to say this once.
Files will never be able to go on them. If you do try to load a file on a clone it will be nothing but a brick for landfill.
There are a lot of eBay sellers selling clones to this date.
Stay away from these sellers unless you want your money to end up in a landfill site, and or looking at a black screen.
ebay seller : discountprojector
http://www.ebay.com/itm/Dreamlink-HD-T6-FTA-IPTV-KODI-XMBC-WiFi-multimedia-receiver-w-DL-300-module-/201488290860?hash=item2ee9a3542c:g:gOkAAOSwJcZWd4JL
ebay seller : titoanita
http://www.ebay.com/itm/Dreamlink-T6-FTA-HD-Satellite-Receiver-KODI-XBMC-with-IPTV-/191757504407?hash=item2ca5a34f97:g:AOUAAOSwf-VWaidh
ebay seller : dalis69
http://www.ebay.com/itm/NEW-Dreamlink-T6-FTA-HD-Satellite-Receiver-KODI-XBMC-with-IPTV-/201484073760?hash=item2ee962fb20:g:hgIAAOSw7FRWbGyG
ebay seller : jan431
http://www.ebay.com/itm/Dreamlink-T6-FTA-HD-Satellite-Receiver-KODI-XBMC-/262192336202?hash=item3d0be18d4a:g:MBgAAOSw~otWb2yQ
ebay seller : baker6199
http://www.ebay.com/itm/Dreamlink-T6-Android-FTA-XBMC-and-IPTV-Brand-New-/262190090973?hash=item3d0bbf4add:g:yX0AAOSwcBhWbczX
ebay seller : ah9882
http://www.ebay.com/itm/Dreamlink-HD-T6-FTA-IPTV-KODI-XMBC-WiFi-multimedia-receiver-w-DL-300-module-/231771023765?hash=item35f6a12995:g:rLkAAOSw5IJWcPRa
ebay seller : dilse316
http://www.ebay.com/itm/Dream-Link-T6-With-Iptv-Built-In-Kodi-Dl300-New-/252216307487?hash=item3ab9436f1f:g:UNAAAOSwfZ1WXwqS
The visible differences that I can see, comparing the original T6 I have here, compared with photos seen on the web
-Mine has the rear power switch with Off / ON showing
-Others has the rear power switch with O/-- showing
-Mine has on the outer gift-box and on the top flap, the bar code is on the same tag as the zone tag, one ontop of the other.
-Others have the bar code on same flap as the zone tag but they are separate.
*I also have 6 or 7 other dreamlink original receivers and they all are the same, with the bar code sticker ontop of the Zone tag.
-Made in Korea insignia is permanent part of the gift-box cover's front design. It's shown in bottom right hand corner, front of gift-box cover.
-Other don't seem to have that. The Made in Korea insignia is missing from box cover.
*I also have 6 or 7 other dreamlink original receivers and they all are the same, with the Made in Korea insignia on the front of gift-box cover.
-My remote keypad's record button has a red dot
-Other remote keypad's record button has a white dot
Check the video below.
It shows the bar code tag in wrong place on the gift-box cover.
It shows the record button with a white dot.
It shows that power switch with the symbols instead of words.
It does not show Made in Korea on front bottom corner of the gift-box.
At 7:47 in the video, you'll briefly see a dreamlink name that flashes just for a second onscreen. I have never seen that on this original T6
https://www.youtube.com/watch?v=2aDEGrot9TQ
That site from above video sells clone receivers of all types. He would get large shipments from china at anywhere form 60 or 70 dollars and up, per receiver.
You can hear him mention about his large shipments and you can confirm the prices at ali-express.
These are just my observations comparing the one I have in front of me and others I have seen on-line. Don't let pictures fool you thou. I seen one ebay with all the correct signs of an original but seems the actuall receiver that is sold may not be the same as what's pictured.
Prove of that is at ali-express sites.
At the china clone site, the pics of the T6 are as I see it, with the signs of an original.
Them pics would have been taken from a original T6 and not of their clone
thanks that is so true dont use dreamlink stuff really will brick your clone dreamlink t6 it sucks they dont tell you that on ebay like aliexpress they tell you dont load any codes in red letters oh i forgot they dont read again you will brick your box with real dreamlink codes if you buy a cheap clone so for all of you get a real Dreamlink T6 and pay the price you'll be happy in long run
