Avov IPTV Problem
Have You Reset Your Modem or Router if You are using Such...?!? If so, check inside their properties and see if the Mac's are what is on the AVOV...! In case You don't know, but You Probably do, the AVOV Mac is listed in the Upper Right Hand Corner of the Server Setting Window...! Inside the Modem an Router You might have to Log-in as Admin to see it, but it is in there also...! Make sure They All are the Same and then Re-Check at the Server Site to see if it is the same there...! Good Luck, certain You will get it... If in Need of More Help, then PM ... crazed 2.4 ...!
I tried everything you told and won't work. On tuesday was working. and then i woke up this morning. and the server didn't connect. and i'm loosing days on my subscription
The MAc needed is actually the TVOnline app's own MAC (TVOnline is the iptv APP).
The actual avov MAC is not the same either. If you look hard enough on that box, you may find the actual avov STB MAc and it will be different then that TVOnline MAC ... alot different, it will not start with prefix 00:1a:79
The router has its own MAC too... as do any device and/or application.
The TVOnline MAC is the one you want, or the WEB app will have the same MAc as the TVOnline MAC too (exact same as it pics it up directly from the instakled TVOnline app))
The one that starts with 00:1a:79
Every device has a different Mac Address......Avov Mac address is not changeable ............... A router would have a mac address also.(because it's a device that is connected to the internet)...but it won't be the one that is in the Avov Box .................None of my Avov boxes ever had the same Mac as the router.....................and they all worked...................
exactly
the router detects the box's mac not the app mac
too bad someone doesn't get that and decides to throw neg rep around
