Authentication problem
Same problem on MyGica 520e with Android 4.2.2
I see the login/password window but nothing I try let's me enter anything. Tried different keyboards, Android soft keyboard, MyGica air mouse with keyboard - nothing works !
Tried both the NFPS official emulator and MyGica MagTV - you just can't type anything in for some reason.
It looks like the login/password is a feature of the MAG 250 which the emulator supports but for some reason keyboard passthrough is not working (except for up/down arrow keys).
Anyone know if there is a data file where the credentials are supposed to be stored ? Perhaps we can just put that in a file.
if you tried usb cable last thing I would try is send your key to your gmail open it from your box.
And copy/paste.
And copy/paste.
on your remote there is a content menu button,,, 3 lines on top of each other,,,,click that and the menu on the right side of your screen will appear,,,settings ect,,,,click on keyboard!
I can enter password but when I press ok nothing happens & I get an error message! Waiting for more instructions here on how to get this to work on android tv boxes....as I see others are having the same issue!
