authentication Issues with NFPS Client on Kodi 17
NPFS was working for past two days
Forget the title i am using Kodi 16.
Now I having authentication Issues with NFPS Client Kodi
was working till turned off the PC now it won't come back on
I've Tried Resetting the mac but it's not working
Is Stalker Down ?
Is Stalker Down ?
I would have to say yes. I needed to turn of my modem off & on and after that I had Authentication issues and after re-setting on papiao twice I am now locked out for the day!!!!
When you have issues, the best thing to do is to check messages here in the server forums first. If you see quite a few messages mentioning down time, you won't create a headache for yourself by tinkering with your settings.
yeh I had the same issues setting it up last night... eventually just gave up got it working with stalker plugin for now
but in my process of clearing stuff a couple times trying to troubleshoot I am now locked out for 24 hours... is there anyway around this... any admins I can message.... ? I understand its for security purposes but maybe the amount of tries you get could be a bit more my 2 cents anyways.
