Audio Sync off and Buffering
MMB10
May 2, 2016
12
yes I do
The audio sync has been off for a couple of weeks now, or since went to HD, and constant buffering on some American Channels, CNN, MSNBC, Fox News, etc.
Is there ANYTHING I can do to fix this, I have done all the fixes I know of, reset router, clear cache, packages, reset everything, turn off (and on) acceleration, reboot.
I am using PVR stalker client and on Portal 5 using Firestick.
Any help would be greatly appreciated :)
same here, if this is the result of the upgrade i wouldn't want to c the downgrade, channels freezing, stucking blackouts box shutting off going straight back to bar loading. ISP or not my box was working good not better but good i dont know what to call this i am experiencing
Thanks I'll check out advanced settings.
There must be a solution to this mystery, some people have this problem and others don't, it doesn't seem like it's a specific portal, or device used, or mbps speed. I have done everything I can think of, cleared cache, packages, IPTV reset, reboot router, guide reset.
I hope someone has the solution and posts :)
Nauditor, do you have audio sync offset problems on those channels too, CNN, Fox news, MSNBC, CI (I guess all the updated HD channel)
I fixed the audio sync offset by turning on media codec (surface) and off the one below it in video acceleration. I fixed the stuttering by turning off OSD in the guide. still have buffering and freezes after a couple of minutes...still unwatchable. Will search for more possible fixes.
