Audio (HDMI / Optical)
bombz
77
Anyone have any issues with DreamOnline getting 5.1 audio to work over HDMI or Optical (spdif) ?
I have tried both.
I have no issues with 5.1 within the kodi back end (on the T1) as Kodi has it's own set of decoders etc.
However with DreamOnline it's a no go. Other STBs I have used testing the same instance, can push 5.1 on sources the T1 can not (perhaps a android codec / decorder issue with DO?)
T1 Settings:
Settings > Android > Sound > Volumes :
HDMI Output = RAW
SPDIF Output = RAW
HBR = RAW 5.1
or
HDMI Output = Close
SPDIF Output = RAW
HBR = RAW 5.1
or
HDMI Output = RAW
SPDIF Output = Close
HBR = RAW 5.1
Soft and Hard reboots after setting change when applied.
