Anyone successfully use Hauppauge or similar device with this box?
If your just trying to use it for OTA channels, then you could use DVB Link Server and then run the DVBLink PVR Client in Kodi. Another way that I have done for my cable card is setup Windows Media Center on a PC and get your card working in it. Then install ServerVMC on the Media Center Machine and the Server VMC Client PVR in Kodi. This will give you all your channels and guide data in your device.
TVOnline doesn't have a capability for OTA. As far as the question goes, the outputs are HDMI and AV, through a miniplug connection. I can't answer the yes/no question directly, but Hauppauge Colossus can record off the HDMI, and the PVRs can record from the AV.
Am I mistaken that this box can run Kodi, i thought it could. If it can then yes you can use TV tuners to get regular TV to on the Box.
