Annoying Channel List Problem
nitrococu
Jun 22, 2016
3
yes i do.
Hi all!
I have a minor problem on mag 254 but it's annoying. I have a private portal. There are +3500 channels in it. I choose a channel (let's say # 300) and watch it with no problem. Then, I press the 'OK' on the remote control to see the list again. Normally, the list should be viewed on the actual page of tv channel which I'm watching at that moment. However, in my case the channel list's going all the way back to first page. As you may agree, it normally shouldn't be like this in any tv receiver.
What I've been wondered is that a portal problem or a device failure ? And what should i do to fix it ?
when i'm watching 200 cnn-I hit ok and the screen goes to 1/4 size on right and epg is on left-the description of what is on is under screen on right side on my mag 254
might be something in your setup. js
hi. i am having the same, very annoying problem...after going thru the channels using channel+/channel - buttons when i press ok to return to the main list screen it takes me to the beginning of the list...very frustrating.. any way to fix this?
