4.4 box with Isengard 15.1
Scepter
Dec 17, 2015
2
Good Morning to all!
I haven't surfed around this site yet suffice to say I've checked Kodi's tech forum. I have a new android 4.4 box which came with 14.1 Isengard connected directly to a 4k TV and is controlled by its own remote and a 3rd party wireless keyboard. Box is connected via WiFi with excellent bandwidth according to the box, although there seems to be a 1-2 second audio delay with some video jitter. I upgraded to Jarvis 16 beta 4.1 arm which made the video much worse, slow and jagged and lost the PCM audio. To rule out HDMI I ran another iptv app and both video and audio are excellent. Obviously there are still some bugs to be worked out in Jarvis 16 but it doesn't seem to be ticketed by anyone. Do I have to uninstall/install of Kodi and return to Isengard?
If things are broke, you might as well go back to where it was better, so you might as well try it. Sometimes box sellers customize the Kodi install with non public addons, so that might be the reason its not working correctly, but that's just a guess. You could try reflashing the box to stock, if they gave you that firmware image. Also, you could try the latest beta version which is now at '4'., or maybe work with your settings to see if that is the culprit.
