Results 1 to 10 of 10
Thread: Sound issue
    Oct 2015
    Sound issue
    This just started happening using the Buzz ap for Tv
    Put a channel on then switch to another channel and sometimes the sound from the previous channel is now mixed in with the present channel I am on
    So two sounds on one channel at the same time
    The only way I can fix it is to reboot
    Nothing different has changed on my end, same provider for 3 years
    Does not matter what channel , it is hit and miss
    Not sure if it has to do with using last channel with remote or not
    It happens sometimes once a day sometimes twice
    Hope the Buzz team can look at it
    try to remove hdmi cable and put it back behind box and tv, try different hdmi cable if you have one, try to clear cache, try to delete server and add again if you can to see if these things helps.
    Jul 2021
    What firmware and software versions does your 4900 have?
    Oct 2015
    Version 5.0.796 updated 01/16/2023
    also tried your suggestions RYU, as of today will report back
    Thank you
    Sure no problem
    Oct 2015
    tried suggestion but no go, sound issue is still a problem
    I would say try a different app for same server and see if you are experiencing same issue.
    If still experiencing same issue then try a factory reset option if possible to see if that helps.
    Oct 2015
    ok, love the Buzz ap though, but i can see
    I believe it has something to do with the 4900
    I have a 3000 and a 3900 on exact same setup with no issues at all
    im not experiencing anything like that on my 4900 using multiple servers.
    sometimes things gets changed on server side so its better to switch media player to make it work properly.
    so I would say try to switch media player if you can before you do a reset.
    Warrior
    Clear cache and close running apps
  1. T1 DD Sound issue
    By reddragon in forum Dreamlink T1
    Last Post: 10-31-2017, 05:56 PM
  2. sound issue
    By roadrunneric in forum IPTV Private Server (Rocket)
    Last Post: 04-04-2017, 03:42 PM
  3. Sound issue
    By petra1000 in forum IPTV Private Server (IPTV66)
    Last Post: 11-19-2016, 08:54 AM
  4. sound issue
    By petra1000 in forum IPTV STB Emulators
    Last Post: 11-18-2016, 02:53 AM
  5. Sound issue
    By richyrich in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 06-07-2015, 01:36 PM
