Results 1 to 10 of 14
    Feb 2016
    iptv 66 android Stb Emulator Pro Please Help
    So I have set up iptv66 and rockets on stb emulator pro 100 times no problems. But as of late I put everything in and then the yellow bar go 25% and gets stuck no matter how long I wait it dose not move. This is for rockets and Iptv66 can someone tell me what is going on? I have reset and changed mac several times cleared cache . I don't know what I am doing wrong???? please help me
    Feb 2016
    No one here can help have they stopped using the stb emulator?????? Any one? 2 words?
    you need to use emulator 8.06.
    I guess other versions are not working anymore
    Aug 2016
    Yes, I Do.
    I'm using 8.06 the iptv66 specific version. No portal ever loads, no yellow bar, just blank screen.
    Edit:
    I have tried YASEm (YetAnotherStbEmulator) in the past, it has not worked, but now I just tried and it actually loaded and let me log in this time! Although I see all the channel listings, none have played so far. Maybe has to do with the media player with this program.
    Aug 2016
    Yes, I Do.
    Just as quick as it "kinda" worked....now it says "Error" when I try to log in at the portal using YASEM.....STB Emu 0.8 is still blank, no portal, no go.
    Quote Originally Posted by matrx1050 View Post
    0.8 is older version. look to 8.06.
    Sep 2016
    Anyone know why the iptv66 stb emu 8.0.6 glitches with the video of the channel going to the top left of the screen when scrolling thru channels in guide?
    It didn't do it with other providers on 8.0.7 and iptv66 doesn't load on 8.0.7 so can't use that anymore, but 8.0.6 does it on every provider
    emu
    This issue (preview window) was fixed in 0.8.07.
    Why doesn't 0.8.07 work for you?
    I'm the developer of IPTV STB Emulator (StbEmu). If you have any questions feel free to ask me.
    Oct 2015
    Yes I do
    Quote Originally Posted by mvas View Post
    I am having problems with stb emu 8.07, when I click on a channel it goes out of the stb emulator and every time I try to go to a channel it does the same.
    Any fix for this and for watching tv with stb emulator on android box?
    Aug 2016
    Yes, I Do.
    iptv66 portal never loads for me....is blank, no login, no loading, no yellow bar. Tried reloading portal over and over. Tried all 0.8 0.8.6 and now 0.8.7
    I the other emu i've been trying, YASEM, got it to work again.....the portal loads, I enter login info. I loads yellow bar. It loads the mag 250 interface. I can see all channels and the guide is up to date. When I try to play channel, doesn't load video, just blank.
    So making me think its iptv66 sometimes and the emu's at other times. I'm sure glad I only got a month to try this out.
  1. Android IPTV STB Emulator
    By dara in forum IPTV STB Emulators
    Last Post: 11-25-2017, 10:36 PM
  2. IPTV Android Emulator
    By matrixebiz in forum IPTV STB Emulators
    Last Post: 12-23-2015, 03:16 AM
  3. Using IPTV 66 Android Emulator
    By patelmo in forum IPTV Private Server (IPTV66)
    Last Post: 11-29-2015, 01:35 AM
  4. IPTV STB EMULATOR for Android
    By p-ben1 in forum IPTV STB Emulators
    Last Post: 09-18-2015, 03:25 AM
  5. IPTV 66 Android Emulator
    By tinieBlax in forum IPTV Private Server (IPTV66)
    Last Post: 08-26-2015, 11:49 PM
