just tried to play with the network settings.........dont do that till you have the tuner.......crashed then stuck in the reboot mode
just did the factory reset.....set it all up again....lol
( just not fun if your not breaking it)
At first glance sleek looking unit
Same remote as the TVonline plus. It also works on the tvonline plus
I realy like the menu
Michyhop
Kodi
ATSC DVB S2
TVOnline
all on the left side
setup basicly the same as the other avov boxes
Two of the greatest qualities
to have in live are:
PATIENCE
and
WISDOM
Try a factory data reset
Manual Factory Data Reset.
1) Make sure the box is connected to the TV by HDMI or RCA
2) Make sure the power is plugged out of the box
3) Push and hold the reset button with the pin for 10 seconds
4) Continue to hold it down and plug the power into the box
5) Hold the reset button for at least another 5 seconds and then let go
6) Proceed to wait for a bit while the box resets, it should open up again in console mode
7) Select the factory data reset option
8) The box will perform a factory data reset and reboot
9) It should then boot normally and start working. If it boots into the console mode again, make sure to just select perform normal boot up (I believe it is the first option)
PATIENCE
and
WISDOM
ya when i did the factory reset looks like if there is a file update you don't just download it or automatically update
but you would download to usb then flash the box?
sure clad I'm not one to gripe and complain right away
first off Kodi and TVAddons would always get stuck at 32 to 50% complete
tried everything i could think of ,Factory data reset,reboot, Manual reset, power off power on
then i realized my internet was slower then heck tonight so i hooked up my cell as personal hot spot
wow everything seams to be working great for set up now
PATIENCE
and
WISDOM
finding my remote to need a push till you hear a click then let off same as the TVonline remote
PATIENCE
and
WISDOM
with the ATSC DVB S2 you get anything
still no turner they said there still waiting for them.........so they can send them out
If you power down the fuse with the power key, then restart the fuse with the same key, all your favorites that you previously saved are gone! This must be a bug.
yea profster asked that long time ago thanks
