Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 132
  1. #21
    I hadn't asked you to reboot but so be it, now we have to fac reset from the BIOS screen..
  2. #22
    Quote Originally Posted by K00lKatT View Post
    Hopefully this will work. My screen is still black. How are we going to get it the bios screen?
  3. #23
    turn rec off...unplug the power jack from rear of rec..as soon as you plug it back in keep repeatedly hitting the menu button on remote..this will bring up the blue bios screen..then go to
    def. settings
  4. #24
    Still doesent come on
  5. #25
    did you get to bios screen??
  6. #26
    No I did not. As I was clicking the menu button the unit goes off and wont come back on I have tried several times
  7. #27
    Can anyone tell me how to get this box to work or should I return it. I bought it from infomir
  8. #28
  9. #29
    When you answered my post yesterday did you read what I had done already and what my problem is now. I am afraid to do the reset for fear I will do something wrong. As long as you know that I can't get anything on the box after trying all the things KatT said to try.
  10. #30
    since you don't like to follow instructions...my advice is to choose Def. Settings(fac default) in your bios screen, the device will boot on it's own, do not uplug
    this will require you to start over..
  1. Setup
    By Fred55 in forum IPTV Private Server (Rocket)
    Last Post: 07-22-2016, 06:10 PM
  2. Need help getting setup
    By firetek in forum PVR Clients
    Last Post: 05-02-2016, 12:17 AM
  3. help setup
    By kilzo in forum IPTV Private Server (IPTV66)
    Last Post: 04-16-2016, 06:28 PM
  4. Mag 254 setup
    By roberto123 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 08-08-2015, 02:47 PM
