I have a jynxbox android m6 6 i'm running kodi helix 14.2 when I try to load kodi 15.2 I get an error not parsing am I doin something wrong loading the addon?
you are not doing anything wrong, kodi 15.2 will not run on Android 4.1, and Jynxbox M6 will not update to Android 4.2, so you are stuck with Kodi 14.2, until someone figures out how to update the m6 box to Android 4.2 or higher.
Use IPTV STALKER addon on Kodi and iptv will work, you can then use SIMPLE iptv client with the IPTV STALKER to get guide, all the tutorials are in the Kodi section.
didnt know that thanks for great info
Well that solved my problem on buying a jynx box streamer ! Thanks!
