Results 1 to 4 of 4
    Serial Numbers Now Required for Kodi Addons
    c/p from NFPS
    Hi.
    If you are getting the error message "Bad or missing Serial Number" is because your client / addon is misconfigured and is not providing the Serial Number to our servers which is mandatory.
    If you are using another client / addon please search in the forum for instructions on how to setup the serial number on that client or simply migrate to one of the clients that allow it.
    In case your Client / Addon allows you to specify a custom Serial Number it is highly recommended to use that option and create your own S/N with 13 random alpha numeric digits.
    For those that are already sending the serial number but still getting this error please try re-linking (remove and add again) your MAC Address to your Donation number by using the following form:
    https://papiao.is/main/search_nfps/
    https://iks66.tv/main/search/
    All donations are valid only for 1 mac address and 1 device only.
    http://iptvtalk.net/showthread.php?9...-in-my-opinion getting the error message "Bad or missing Serial Number" thank-you
    Copernicus Crater
    Now a Sticky. Thanks Dara
    Serial number and Device Id are also required for the STB Emulators, but the credentials can't be easily transferred to Kodi addons.
  1. Replies: 14
    Last Post: 04-26-2016, 06:50 PM
  2. Replies: 0
    Last Post: 01-26-2016, 12:12 AM
  3. Add Addons to Get the Most out of KODI
    By BIO in forum Addons & Repositories
    Last Post: 01-11-2016, 03:32 PM
  4. Bad or missing serial number on IPTVSTALKER kodi
    By bigshadow in forum Kodi Discussion
    Last Post: 10-28-2015, 06:35 PM
  5. hi all kodi iptv help required.
    By stevie1978 in forum Kodi Discussion
    Last Post: 07-05-2015, 05:12 PM
